File extensions and saving (bug)
Spielorjh
Post by Spielorjh »
I found a problem that I can reproduce under the following steps:<br><br>1. &nbsp;Create a new file<br>2. &nbsp;Select "File/Save as"<br>3. &nbsp;Type in a filename, but do not type a file extension.<br>4. &nbsp;Make sure that "Rich Text Document" is selected as the type of file.<br>5. &nbsp;Click Save.<br>** At this point, the file is created, and is an RTF file, but the filename is simply [filename], not [filename.rtf]. &nbsp;EVERY OTHER editor program I know of, be it Notepad, Wordpad, Word, etc, will add the file extension for you.
Max_Quordlepleen
Re: File extensions and saving (bug)
Post by Max_Quordlepleen »
I just tried this. I created a new document, selected save as. It gave me a suggested name "Doc87.rtf" I deleted that and just typed blah - no extension. After saving, the name of the document showed up as blah.rtf.
Salaam alaikum, noho ora mai
Atlantis never adds a file extension if the filename is terminated with a fullstop:<br><br>blah.<br>
Spielorjh
Post by Spielorjh »
Hmm.<br><br>So it does.<br><br>Glad that was easy, then.<br><br>Thanks.
