Scanner Compatibility
Blackie
Post by Blackie »
What I find would be extremely useful is having Atlantis able to bring in copies from a scanner/camera feature. I do a lot of updating of documents which have previously been used and would like to update them when necessary without having to retype and reconfigure everyting all the time. Is this a possibility?? thanks.
If you mean converting a paper document to the electronic file, this would not be possible with Atlantis. You would need ABBYY FineReader or a similar software.
Guest
Post by Guest »
Thats the Wrong Link http://www.abbyy.com/ doesn't work. It is http://www.abbyy.co.uk
I cannot say why abbyy.com does not work in your browser. But it is the main domain name of this company:
maxqnz
Post by maxqnz »
Guest wrote:Thats the Wrong Link http://www.abbyy.com/ doesn't work. It is http://www.abbyy.co.uk
The .com link works just fine for me.
