Compliments and a Suggestion
mgomgo
Post by mgomgo »
-New columns feature: &nbsp;cool!<br><br>-Supercompact RTF feature: &nbsp;Excellent! &nbsp;I have been able to reduce the sizes of some seriously bloated Wordpad docs by about 1/3 with no loss of graphics quality!<br><br>-One suggestion: &nbsp;I know you are proud of your product (as you should be!), but how about a registry hack to stop the splash screens when we install a newer version? &nbsp;Including the .cod splash screens, too! &nbsp;Going in and adding "-nosplash" in the registry is a hassle sometimes!<br><br>I can see where the splash screen on the freeware version would help encourage folks to purchase the program. &nbsp;But if we already bought the license, it seems to me we could have an option on install to not load the splash screen.<br><br>Thanks!<br>-michael goodrich<br>Tucson, Az &nbsp;USA<br><br>
Van
Re: Compliments and a Suggestion
Post by Van »
been discussed before, just add 'no splash' to your shortcut like this<br><br>"C:\Programs\Atlantis\Atlantis.exe -NoSplash"<br><br>in Target (properties of your Atlantis shortcut)<br><br>V
Out with it...
Max_Quordlepleen
Post by Max_Quordlepleen »
Van wrote:<br>been discussed before, just add 'no splash' to your shortcut like this<br><br>"C:\Programs\Atlantis\Atlantis.exe -NoSplash"<br><br>in Target (properties of your Atlantis shortcut)<br><br>V<br>
<br><br>I just tried that, so that my shortcut Target read like this:<br>"C:\Program Files\Atlantis\Atlantis.exe -NoSplash"<br>and when I try, I get this error message: " The name 'C:\Program Files\Atlantis\Atlantis.exe -NoSplash' specified in the Target box is not valid. Make sure the path and filename are correct." <br>Both the path and the filename are correct - any ideas what I might be doing wrong?
Salaam alaikum, noho ora mai
1953
Post by 1953 »
Try after exe"There must be a space and then -NoSplash otherwise it will not work
Max_Quordlepleen
1953 wrote:<br>Try after exe"There must be a space and then -NoSplash otherwise it will not work<br>
<br><br>If you look at the line I pasted, you will see that there already is a space between exe and -NoSplash<br><br>As it turns out, the line should look like this:<br>"C:\Program Files\Atlantis\Atlantis.exe" -NoSplash<br>which is what your reply to my question suggested, but was NOT how you phrased it in your inital post, I quote:<br>"C:\Programs\Atlantis\Atlantis.exe -NoSplash"<br>That misplaced " in your initial post was the problem.  :D
1953
Post by 1953 »
This is how mine is."C:\Program Files\Atlantis\Atlantis.exe" -NoSplash<br>
Max_Quordlepleen
<br>
1953 wrote:<br>This is how mine is."C:\Program Files\Atlantis\Atlantis.exe" -NoSplash<br><br>
<br><br>Yes, that's right, but if you look at your initial reply to mgomgo, you will se that that is NOT what you put. Instead, you put,
Of course. By the way, quotes are not necessary in this case at all:<br><br>This should work too<br>C:\Programs\Atlantis\Atlantis.exe -NoSplash<br>because<br>C:\Programs\Atlantis\Atlantis.exe<br>is not a "long filename".
1953
Post by 1953 »
Max_Quordlepleen wrote:<br><br><br>Yes, that's right, but if you look at your initial reply to mgomgo, you will se that that is NOT what you put. Instead, you put, <br><br>
<br>Max I think you have got me mixed up with Van.
Max_Quordlepleen
<br> :-[ :-[ :-[ :-[ <grovel>Mea culpa, mea culpa, mea MAXima culpa!</grovel><br><br>(Note to self: remember to read posts before ascending one's high horse)
1953
Post by 1953 »
;) ;D :D My trick, is usually my mouth works 5 seconds before my brain... I was worried to log back on to the forum just in case I made the mistake, and you was going to tell me off again Max. ;D
Atlantis Ocean Mind 1.1.2.5 has a new option: “Show splash screen at startup” (“Tools | Options…”, “General”). This new option allows to disable the splash screen in a much simpler way.
