Insert Smileys
communication
Insert Smileys
Post by communication »
Hi!
I want to insert Smilieys in the text. Is this possible, for example by the way: insert/Symbols
I find nothing in the Help and also no information in the forum.
communication
Re: inserting smileys
Greetings–
If you want to insert textual smileys, you can create a custom Clip Library including your favorite emoticons. They are inserted like any other item from an Atlantis Clip Library.
If you want to insert graphic smileys, you must have the corresponding pictures on your hard drive. These are inserted like any other picture type. You can also create a custom Clip Library including your favorite graphic emoticons.
