TipCtrl+PgUp moves the cursor to the beginning of the previous page.
Getting started
Welcome to the Atlantis Word Processor Help.
Use the "Navigation" pane on the left or the "Search" box above to find the required Help article.
Important notes:
  • Throughout the Help topics, Atlantis Word Processor will be referred to simply as Atlantis.
  • The current Help information applies to the current version of Atlantis. Please make sure that your copy of Atlantis is up-to-date.
  • Most windows of Atlantis contain the Help button in the title bar:
    The Help button in the title bar of a dialog window
    You can click it or simply press F1 for the info about the window.
  • The Help topics refer to the default hot keys of Atlantis. The hot keys in your Atlantis might differ if they were adjusted through the "Tools | Hot Keys..." menu command.
    Some toolbar buttons mentioned by the Help topics, might be unavailable on your toolbars in Atlantis. You might need to install them to your toolbars through the "Tools | Customize | Toolbars..." menu command.
