TipThe "Font" drop-down on the toolbars normally displays the font name of the currently highlighted font face in the corresponding preview. But it will display a preview of the current document selection if there is any.
The "Activate Window" dialog
The 'Activate window' dialog
You can normally access this dialog by pressing Alt0, or choosing the "Window | Other..." menu command (when you have 10 or more documents open).
This dialog displays the list of documents currently open in Atlantis.
To activate a document, click its filename, then press the OK button. Alternatively, just double-click the document filename.
Tip:
  • You can quickly switch among the open documents by pressing Alt1, Alt2, ..., Alt9, or CtrlTab.
