TipIn Atlantis, each font face can have its own custom hot key (use the "Tools | Customize | Hot Keys..." menu command). The font face can then be applied to any text selection directly from the keyboard.
The "Address Books" dialog
The 'Address Books' dialog
You can normally access this dialog by choosing the "Insert | Addresses..." menu command or clicking the Insert addresses Button image button of the Insert toolbar The 'Insert' toolbar , then clicking the Manage Address Books button.
The Address Book folder box tells the location of your address books (the folder where all your address books are stored). To view address book files in the file manager, click the View... button.
The Available Address Books box lists the books available under your Address Book folder.
You can create a new address book by clicking the New... button.
Click the Edit... button if you want either to view or modify the addresses of the address book selected in the Available Address Books box.
The Delete button completely removes the address book selected in the Available Address Books box. Be careful when deleting address books because this operation cannot be undone.
