You can normally access this dialog by pressing CtrlD, or choosing the "Format | Font..." menu command, or clicking the Font format button of the Font toolbar .
The dialog can be used to modify the font format of the selected document text.
Click the Default... button to make the current font format the default font format in Atlantis. The current font format would be saved to the default document template used by Atlantis to create new documents.
Click the Copy button to place the current font format onto the Font Format Clipboard, a proprietary storage buffer of Atlantis meant for font formatting.
Click the Paste button to load the formatting from the Font Format Clipboard to the dialog.
