TipF9 toggles the "Full Screen" mode on and off. With the Full Screen mode on, the Atlantis toolbars, scrollbars, document bar, status bar and rulers, all become invisible by default. To go back to the Atlantis normal working environment, simply press F9 again or press Esc. Note that you can choose which components of the Atlantis interface are displayed in the Full Screen mode. Use the View tab of the "Tools | Options..." dialog.
"Print Envelopes" dialog
Printer options
The Name box lists the printers connected to your computer. Choose the desired printer from this list.
Click the Properties button to set up options for the printer such as print quality, paper source, etc. The actual options depend on the printer's specific features. When you click the OK button, Atlantis memorizes the current settings of your printer. The next time you call this dialog, Atlantis will restore the last used printer with its last used settings.
If the Print to file box is checked, the envelopes will be printed to a file instead of routing them directly to a printer. The envelope is saved with the printer formatting, such as font selection and color specifications, in a .prn file that can be printed on another printer.
Copies
With the Number of copies box you can specify the number of copies of identical envelopes you want to print.
When you have selected more than one copy, the Collate box specifies whether you want the copies to be collated.
