"Tabs" dialog
Use this dialog to adjust the tab settings for the selected paragraphs, or for the style.
To change the numeric value of the desired tab position, double-click it, or click Modify.
Click Add... to add a new tab position.
Click Delete to completely remove the selected tab position.
