English Spellchecker
skyborn
Post by skyborn »
Dear Atlantis,
I just logged onto the forum. Seems the spell checker problem is a common one. I have the U3 version, and it consistently says there is no English
spell checker installed. I go to tool/options and try to install it but all to no avail. I just now dl the latest U3 .6 version and it still says there's no spell checker. PLEASE HELP.
Skyborn
We admit a problem in the U3-smart version of Atlantis: if you click the "Cancel" button in the "Tools | Options... > Spellcheck > Spellcheckers & Dictionaries..." dialog, the spellcheckers (temporarily) stop working. But if you restart your U3-smart Atlantis, everything should work correctly. A fix will be included in any next build of Atlantis. Please uninstall your U3-smart Atlantis through the "Manage Programs" feature of the U3 LaunchPad, then download the patched setup file of U3-smart Atlantis:
http://www.atlantiswordprocessor.com/do ... 6en_u3.exe
and use it to reinstall the U3-smart Atlantis to your USB drive. The "Cancel" button in the "Tools | Options... > Spellcheck > Spellcheckers & Dictionaries..." dialog should now work correctly.
Does now everything work correctly?
As I understand, the spellcheckers of your U3-smart Atlantis now work correctly. Thanks.
