It would be great if Atlantis would return to the place in the text where you launched a Find/Replace All task. In most cases, when editing a large file you come across a misspell and want to correct it everywhere in the text, and continue with your work afterwards.
thanks
cyana
Find & Replace Return Point
Hi Cyana,
When you do a “Ctrl+H” operation, you’ll automatically be taken back to the first replacement Atlantis made if you have been careful to choose “Backward” as the “Search Direction” in the “Ctrl+H” dialog before pressing “Replace All”.
Of course, this will work only
1. If you have started the “Ctrl+H” operation from the end of the document,
2. Or if you have made a selection before calling the “Ctrl+H” dialog.
To make the most appropriate selection in such cases, I suggest placing the caret before the first instance to be replaced, and pressing “Shift+Ctrl+End” (this will select all the document from the insertion point onwards).
