Hello, and Thank You! for such a marvelous & Powerful app! Really !!
( Word/.docx -- who????
Studying through your Help files, I find what I am looking for under --
"Hot Keys. Commands For the Cursor Movement" -
... specifically, Ctrl + Home/End = Top/End of the document.
However, whilst searching through "Show All Assigned Hotkeys..." ,
I do not find the ability to modify any hot keys for cursor movements --
... would you kindly tell me if it is possible to do this, & if so, How?
I'm using v1.6.5.9, and under "regular" Windows (XP or 7) these default commands are wonderful,
for I am binding them to StrokeIt mouse movements,
and how convenient that they are the SAME commands for going to the Top/Bottom of Windows Explorer
(or 3rd party file mgr -- xplorer2, explorer++, Q-Dir, etc) file-pane windows, and also internet browser pages !
But! ... it is a different situation under BootCamp 3.3 Win.7.sp1 x86 on a mid-2007 A1181 white Macbook
Under BootCamp, with the Function button enabled in BootCamp, through trial/error I discovered that
Fn + Ctrl + Home/End (the L/R arrow key) = Top-Beginning / Bottom-End of document.
So for me, after I assign my bindings in the Logitech Gaming Mouse control panel,
this works out that I press Ctrl + L/R-click mouse buttons to go Top/Bottom of document,
which is really, really a minor thing --
vs. simply L/R -click whilst in Win.Explorer/file mgrs/browsers;
... but still, I wonder, is there some way I can reassign the hotkeys that control Cursor Movement?
(because I also just naturally want to tinker with these things
or, is that inviting too much problems from end-users to make such functions available?
(if so, I surely understand -- I'm just glad I contemplated a work-around for myself)
Thanks so much, & Best to you!!
