File dialog box too big.
kitimat
Post by kitimat »
I usually have Atlantis on the right hand side on the computer screen (widows key + right arrow) and have the course video playing on the left side (windows key + left arrow) . The issue is that the Atlantis file dialog box comes up centered on the screen and not centered over the Atlantis program. Also the file dialog box is very large.
Is there a non-verbose setting for the file dialog box?
Can it come up centered over the application?
The file dialog box can be resized, but it cannot be shrunk beyond a minimum size set by Windows. Also in such a case it could not be centered over the Atlantis program because it would not fit within the available window width.
This is only mildly inconvenient and only lasts for the time it takes to select a file.
I am afraid you’ll have to put up with it…
kitimat
Post by kitimat »
I was hoping that I had missed an option.
I can do a work around.
thanks
