Some of you might be interested in this free utility. It will help you keep the Atlantis window “always on top”.
Here is from Always on Top: Keep Any Window Visible Always:
HTH.Say you are checking your emails in Google Chrome and simultaneously watching a YouTube videos in VLC on your small screen laptop. The problem is that if you switch to the browser, the media player window moves to the background and vice-versa.
If you would like to prevent that video window from hiding even while you bring the browser to the foreground, you may download “Always on Top” – a free utility that will “stick” any program window to the foreground of your desktop with a simple keyboard shortcut.
To get started, download the Always On Top utility from labnol.org (<200k) and run it. Then select the window you like to keep on top and press the Ctrl+Space shortcut to stick that window in the front.
You no longer have to worry about arranging windows side-by-side to copy-paste information from one window to another. If you like to disable sticking and restore the default window behavior, just press the same Ctrl+Space shortcut again.
