I’d like to have an available toolbar button and corresponding hot key to turn on and off the Spellcheck As-You-Type feature; using the pop-up menu that appears when right-clicking on the little dictionary icon on the Status Bar is a bit tedious, especially when using Full Screen with Status Bar hidden. (I never use the old one-word-at-a-time dialog box style Spellcheck myself; I much prefer to turn on Spellcheck As-You-Type and then quickly scan for red squiggly underlines to find potentially misspelled words, but I'd like to be able to turn it on and off quickly and conveniently.)
All that’s really needed is to assign Spellcheck As-You-Type its own separate “command” and button (I suggest one like the existing Spellcheck button but with a red squiggly line replacing the blue check mark), and then I could take care of the rest with the Toolbars... and Hot Keys... and Menus... tools.
