1) Can Atlantis concatenate rtf files?
I want file(new) = file(1) + file(1) ...file(n).
2) Can I get Atlantis to delete the file that I am presently viewing?
thanks
file concatenation and delete
Hi kitimat,
1. Save any Clippy Bank contents if necessary.
2. Press “Ctrl+Alt+F8” to “Empty Clippy Bank”.
3. Open file(1) in Atlantis or switch to it if it is already open. Press “Ctrl+A” to select it all, then “Ctrl+F8” (“Append to Clippy Bank”).
4. Open file(2) in Atlantis or switch to it if it is already open. Press “Ctrl+A” to select it all, then “Ctrl+F8” (“Append to Clippy Bank”).
5. Open file(n) in Atlantis or switch to it if it is already open. Press “Ctrl+A” to select it all, then “Ctrl+F8” (“Append to Clippy Bank”).
6. Switch to the Clippy Bank (or press “F8” if it’s not already open).
7. Press “F12” and save the Clippy Bank contents under any suitable name and file type.
1. First, press “Ctrl+W” to close the document that you want to delete.
1. Still in Atlantis, press “Ctrl+O”.
2. Use the “Open Document” dialog window to navigate to the document that you want to delete.
3. Right-click that file, then select “Delete” from the context menu.
4. Close the “Open Document” dialog.
Here is how I would go about this.1) Can Atlantis concatenate rtf files?
I want file(new) = file(1) + file(2) ...file(n)
Not through a direct Atlantis command. But it can be done from within Atlantis.Can I get Atlantis to delete the file that I am presently viewing?
