Difficulty with copying the attached
ironhat
Post by ironhat »
Here is a snip of a webpage which I wish to save for my own use however, the formatting won't copy. Perhaps I can't copy it and that's OK too. It's just a little difficult to read. Here's the snip.
Well, I'm not able to post it with Snipping Tool or Print Screen, hmmm. OK, here's the address for you to look at and tell me if it can be simply done. http://cartridgecollectors.org/?page=headstampcodes#A
Either way, Thanks,
Charles[/img][/code][/quote]
Hi Charles,
This Web page contains a HTML table. Atlantis has no support for tables yet. So it won’t paste AS IS into Atlantis.
Currently, the best you can do is to create a screen capture of the table and insert it as a picture into Atlantis.
Or even better, you can use the browser “Save As” or “Save Page” command to save this Web page as a “Web page, complete”. You’d get something like the attached HTML file that will open offline in any browser.
Headstamp Codes - International Ammunition Association.zip
(345.31 KiB) Downloaded 804 times
Note:
If you have Google Chrome as a browser, you can go to any Web page of interest through Google Chrome, press “Ctrl+P” and save the page as PDF. These are state-of-the-art PDFs.
