Horizontal splitter within document window?
Aitch748
Post by Aitch748 »
I know you're all working hard right now on getting tables implemented in Atlantis, but would you consider, for a future version, adding the ability to split a document window (as Word can), so that you can see two different parts of a large document at once (and scroll each independently)?
This is not yet implemented, but you can save your document under a different name (F12), and display both the original and the copy in the Side by Side mode (“Window | View Side by Side With…”)
You might want to have a look at the following help pages:
View Documents "Side by Side"
Simulating parallel columns with the "Side by side" mode
