Insert Picture
Fixit
Insert Picture
Post by Fixit »
I have Atlantis Word Processor 3.1 installed as portable on F:\ flash drive, when I use main menu/insert/picture to insert a picture in a document Atlantis creates a new folder “Pictures” on C:\ as C:\Users\Pictures, which Pictures folder is empty. I want insert picture to open F:\Atlantis\Clip Library “not C:\Users\Pictures” when I click insert picture from main menu, how can I do this.
Use the drop-down attached to the “Insert picture” toolbar button, or the “Images” sub-folder in the Clip Library panel of the Control Board.
Fixit
Post by Fixit »
Thank You. This one works "Images” sub-folder in the Clip Library panel of the Control Board", and will NOT make folder Pictures on C:\. This one still
makes a Pictures folder on C:\ "Use the drop-down attached to the “Insert picture” toolbar button".
Atlantis does not create the “Pictures” folder in Windows. The “Pictures” folder in Windows is a Windows system original folder.
Atlantis can only be directed or redirected to the desired “Pictures” folder.
jakobcornelis
Post by jakobcornelis »
I am setting up AWP to produce 3-column pages. How can I insert a picture across two (or three) columns?
New User
Basically, you need to format your picture as a 1-column paragraph. It will be separated from the 3-column text through continuous section breaks. You can then center-align the picture within its own section.
See attached “Picture across columns.rtf”.
(129.11 KiB) Downloaded 542 times
