Wish: Document bar always just beneath the other toolbars
VJF
Post by VJF »
Is it possible to (make to) have the document bar always just beneath the other toolbars. I've 3 rows.
Thanks in advance.
Vincent van Gool
Vincent van Gool, Amsterdam
View | Document Bar > Position > Top
VJF
Post by VJF »
Helas,
View | Document Bar > Position > grey.
I want the document ALWAYS in that place at the top. Despite the presence of other toolbars. Independent.
Thanks for a solution.
The Document Bar needs to be visible for the related menu commands to be available.
First, make sure that at least 2 documents are open in Atlantis.
Then, activate “View | Document Bar > Show” if the Document Bar is not already showing.
Finally, click “View | Document Bar > Position > Top”.
Note that the Document Bar will only be visible when at least 2 documents are open if “Hide Document Bar for single document” is activated on the “View” tab of the Atlantis global options (“Tools | Options > View tab”):
