altantis slow...
altantis slow...
hi - when i'm working with a RTF document over 20 pages the typing becomes extremely slow and difficult, it could take one second to delete each character, etc. it's not the computer (new up-to-date machine). the sluggishness seems to be based on the size of the document. is this consistent with other users? thanks, jeff (ps - otherwise I enjoy this program immensely).
Could you send your document to comment@rssol.com ?
Thanks for your document.
The problem is that it contains a huge paragraph. This paragraph contains about 30,000 characters. Atlantis performs spellcheck-as-you-type paragraph-by-paragraph. Every time you make changes to this huge paragraph, Atlantis has to re-spellcheck this paragraph. This is a quite time-consuming operation.
Solutions:
a) Split that huge paragraph to smaller paragraphs.
or
b) Disable the “spellcheck-as-you-type” (choose “Tools | Options”, “Spellcheck”, uncheck “Check spelling as you type”).
Solutions:
or
slow down
When I turn on one or more sound events in Atlanis 1.1.2.8, the program slows down until there is no reaction when I press any key on the board.
When I turn off the sound event(s) all works again right.
In older versions, there is no problem like this.
