Does Atlantis support the alignment of the text grid at the bottom of the page? I am not sure how to make the pages look even when there is spacing between the lines. Sometimes the text doesn't seem perfectly aligned with the mirror page.
Also, is there a way of increasing/reducing the kerning of the letters in the individual lines to avoid the formation of large or tight spaces? You know, those advanced tricks that make a document look professional.
Thanks
Question - Text grid
There is no text grid in Atlantis. But you can try the fixed line height for the paragraphs ("Line spacing > Exactly" in the "Format | Paragraph..." dialog).
To change the intercharacter spacing of the selected characters, use the "Spacing" box on the "Spacing" tab of the "Format | Font..." dialog, or press Ctrl+Alt+Left Arrow or Ctrl+Alt+Right Arrow.
