Outlining Broken
LN108
Outlining Broken
Post by LN108 »
I've been using Atlantis for years. This is the first tech support request I've submitted in a long time. My outlining function seems broken, perhaps with a recent update. Symptom:
When I create an outline, level 1 is inserted with no problem. However, when I hit tab to create a level two item, proper letter/number and punctuation are inserted, but without any indentation. If I hit tab again, the numbering changes, but again, no indentation. The numbers/letters stay at the left margin. See this video captures:
https://www.screencast.com/t/9rNn4PPCY
https://www.screencast.com/t/4lNZ1YCdb
Thanks for any advice! LN
Re: Outlining Broken
The next maintenance release of Atlantis Word Processor will have this fixed. It should be available in the next few days.
We apologize for the inconvenience.
Thanks for reporting.
Please use the "Help | Check for Updates..." menu command of Atlantis to install the latest version with the fix.
