"save documents" doesn't save
Nearly all my Hot Keys work.Not, though, Save Documents. I have both the assigned hotkeys, and a simple F2 hot key (to press while working, so as not to lose stuff.) Tonight, I started New Document, wrote a few words, tried saving. It didn't save. I used the command on "File" o save, and it seemed to work. I wrote a few nonsenseletters, pressed the Official Assigned Key, then my own assigned key. Nothing worked. Went onto "File: Save as. It didn't' work. Other hot keys were fine. So I tried it on another file. Nope. No saving with buttons. Not even "Save as". Weird. The Load/Replace stuff all fine. Any help from Atlantis geniuses?.I may delete all assigned keys and start all over, but hope that isn't necessary.
Re: "save documents" doesn't save
Er.....I think it works now. Nothing I did. Just the gods taking pity on me. No reply necessary
