I ran into some clipboard conflicts recently, after using Atlantis and, more recently, using Atlantis' clipboard monitoring (1) in tools > options > edit > clipboard management and (2) clippy bank. One of the issues was serious and has happened twice since starting to use Atlantis.
For years have I used Ditto clipboard manager and it is one of my techno best friends. I suspect the clipboard issues are between Ditto and Atlantis. For clipboard stuff I definitely prioritize Ditto over Atlantis.
For now I have turned of Atlantis clipboard manager and clippy bank. Is there a way, beyond what I've already done, to 100% guarantee Atlantis does not mess with my clipboard in any way? Though I don't like to, I would be willing to dive into an ini file if necessary.
Thanks.
is there a way to 100% disable any and all clipboard monitoring in Atlantis
Re: is there a way to 100% disable any and all clipboard monitoring in Atlantis
Every time you launch Atlantis, it registers itself with Windows as a so called clipboard viewer. Atlantis needs to monitor data that goes to the Windows clipboard for the “paste” commands to work correctly. This cannot be disabled. But I also do not think that this could be a source of any conflict.
Anyway you can try launching your clipboard utility after launching Atlantis. In this way your utility would appear at the top of the chain of the clipboard monitoring applications.
