Atlantis Word Processor 4.3.5 (beta)
Atlantis Word Processor 4.3.5 is available for betatesting.
This version introduces a new module for automatic hyphenation. All the spellcheckers of Atlantis now include hyphenation pattern files enabling automatic hyphenation in Atlantis for corresponding languages.
The setup of this beta automatically installs the hyphenation files for the English language. To enable automatic hyphenation for other languages, you can download and install the corresponding spellcheck & hyphenation add-ons.
Setup file of Atlantis Word Processor 4.3.5.0 (size: 2.8 MB) (build a5, released on Nov 20, 2023)
Rui
Re: Atlantis Word Processor 4.3.5 (beta)
Post by Rui »
Hello.
Hyphenation in languages other than English is very welcome. However, the Portuguese corrector is not Portuguese PT, but Portuguese br. Selecting Portuguese - Portugal, the correction is made for Portuguese - Brazil.
Fixed. Please choose the "Help | Check for Updates..." menu command of this beta. Thanks.
Eduardo
Sounds
Post by Eduardo »
Thanks for the new update.
I noticed once I updated Atlantis to the present beta, it didn't install the basic sound scheme. It also erased some custom settings like the text cursor options.
I hope this helps.
E.
Eduardo
Updated from which version?
Version 4.3.5 is about hyphenation, not text cursors or sounds. You can use your file manager to open the “user files” folder (indicated on the “Load/Save” tab of the “Tools | Options” dialog of Atlantis), and check if it contains the “Basic.asn” file. Note that installing a sound scheme does not necessarily mean activating it. You may need to choose the “Tools | Customize | Sounds...” menu command of Atlantis to enable sounds.
