Menu item or command to open file location in explorer
graatch
Post by graatch »
With files in different places it helps to be able to jump to something, since the save dialog defaults to the last location saved in, not to do with where the file is. I know about the full file path display option, which is helpful partly; still I've long wished for a fast jump in the file menu, a la "Open Containing Folder" in notepad++
I would also like to see Document Properties function expanded to show more information, including certain file details like size, path, tags.
<3
Re: Menu item or command to open file location in explorer
Why exactly do you need to open the folder containing the active document file?
By the way, when the “Save As dialog offers to save in same folder as the original document” option is checked on the "Load/Save” tab of the “Tools | Options...” dialog of Atlantis, the “File | Save As...” command opens the folder containing the active document file, not the most recent folder.
Version 4.4.0.6 will have this command in the right-click menu of the Document Bar.
