TipAtlantis supports document projects.
AtlanTips
Deleting table cells or rows with keyboard
Document selections can contain whole cells and/or rows:
Selected cells
If you then press the Delete key or click the Delete Button image button of the Edit toolbar The 'Edit' toolbar , you remove all contents from the selected cells/rows, but the cells/rows themselves are preserved as containers:
Blank cells
On the other hand, if you want to completely remove the selected cells/rows along with their contents, you need to press the Backspace key instead. With this result:
Deleting cells
