TipYou can use the "Edit | Go To..." menu command, or press Ctrl+G, or double-click any of the 2 leftmost status bar sections to call the "Go To" dialog. Use it for quick navigation to any specific page, section, paragraph, bookmark, footnote, endnote, or table.
AtlanTips
How to get the spellchecker suggestions from the keyboard
When we encounter a misspelt red-underlined word in a document, most of us usually grab the mouse and right-click the word for a list of suggestions from the spellchecker:
Misspelling
If one of the suggestions is appropriate, a click on it fixes the misspelling.
However, you might find it quite inconvenient to have to switch to the mouse each time you want to have a look at the list of spelling suggestions. No problem! You can display the spellchecker suggestions from the keyboard. Just place the insertion cursor within the misspelt word (or immediately after its last letter), and press the Menu key on your keyboard to display the spellchecker suggestions for the current red-underlined word.
The Menu key looks like this:
The 'Menu' key
