TipYou can edit the list of predefined font sizes offered on the Atlantis toolbars. Click the "Font Sizes..." button on the Edit tab of the "Tools | Options..." dialog.
Customizing hot keys
You might find it convenient to perform various commands in Atlantis through the keyboard. For this most commands in Atlantis can be associated with a hot key. Pressing an associated hot key allows to execute the corresponding command.
Most commands in Atlantis initially have associated hot keys. You can adjust these hot keys to fit your personal. For this choose the Tools | Hot Keys... menu command. The Hot Keys dialog would pop up:
You must select the relevant Category on the left first, then browse the Commands list on the right and select the target command.
When the desired command is selected, the Assigned hot keys box displays the hot keys currently associated with it. "(None)" is displayed in this box when the selected command has not been assigned a hot key.
To assign a (new) hot key to a selected command, you can either
  • click inside the New hot key entry box, then press the desired hot key on the keyboard. A warning message will pop up if the chosen hot key is already assigned to a different command.
  • or press the ... (3 dots) button next to the New hot key entry box. You can then choose any appropriate hot key from a list of the currently unused hot keys.
Note that in both cases, it is necessary to press the Assign button to save your choice of a (new) hot key. Also if needed, you can assign multiple hot keys to the same command.
To remove an already assigned hot key, click it in the Assigned hot keys box, then click the Remove button.
The Original hot keys box displays the default Atlantis hot keys for the selected command. After changing hot keys for a command, you can always revert to the original hot keys for this command by clicking the Restore Original Hot Keys button.
The original default Atlantis hot keys for all commands are restored by pressing the Restore All button.
Atlantis supports both simple and compound hot keys. Simple hot keys are single keys or combinations of Shift, Ctrl, Alt, and another key, e.g.:
CtrlA
F1
ShiftG
CtrlShiftU
AltShiftP
CtrlAltShiftF8
A compound hot key is made up by a key preceded by any of the following key combinations:
CtrlK
CtrlShiftK
AltShiftK
For example, the following are compound hot keys:
CtrlK1
CtrlShiftKF2
AltShiftKU
Compound hot keys are 4-steps hot keys. Let's take CtrlShiftKU ("Split Paragraphs") as an example. You must:
  1. Hold the Ctrl and Shift keys pressed,
  2. Press and release the K key,
  3. Press and release the U key,
  4. Finally release the Ctrl and Shift keys.
Note:
Hot keys can only be assigned to the font sizes listed in the Tools | Options... > General > Font Sizes... dialog. So if you want to assign a hot key to a font size not yet included in the Font Sizes dialog, you must add that font size to the Font Sizes dialog first.
A similar note holds regarding assigning hot keys to font colors and highlight colors. Hot keys can only be assigned to the colors offered on the Atlantis color palettes:
Color palette
Tip:
  • The various menus of Atlantis and the toolbar hints include information about the hot keys associated with the corresponding menu items or toolbar buttons.
