TipYou can convert multiple documents to a different format with the Batch conversion tool.
Deleting text
You can delete either a single character from the active document or a selected text fragment.
To delete a single character, use one of the following methods:
  • Place the blinking cursor immediately before the character that you want to delete, then press the Del key or click the Delete Button image button of the Edit toolbar The 'Edit' toolbar .
  • Place the blinking cursor immediately after the character that you want to delete, then press the Backspace key.
To delete a text fragment, select it, then press the Del key or click the Delete Button image button of the Edit toolbar The 'Edit' toolbar .
If the document selection contains only entirely selected table cells or rows, pressing the Del key or clicking the Delete Button image button of the Edit toolbar The 'Edit' toolbar clears the selected cells/rows but does not delete the cells/rows. To entirely remove the selected cells or rows from the document, press the Backspace key.
