TipWhen you drag the ruler items with the mouse, you will be able to set more precise values if you hold the Alt key down at the same time. Click for details...
Sending documents by email
Sending documents as attachments
To email the active document as attachment, click the Send document by email Button image toolbar button, or choose the "File | Email | Send by Email..." menu command.
To send all open documents as attachments of the same message, choose the "File | Email | Send All by Email..." menu command.
To zip the documents and attach them to a new email message, ready to be sent in your default mailer, choose the "File | Email | Send by Email Zipped..." or "File | Email | Send All by Email Zipped..." menu commands.
Note that in order to be able to email documents from within Atlantis as attachments, you need a MAPI-compatible email client on your system, like Mozilla Thunderbird.
Sending documents as a direct email message
To email the contents of a document not as attachment, but as a direct email message:
  1. In Atlantis, select a fragment or the whole of the document that you want to email.
  2. Press CtrlC to copy the selection to the clipboard.
  3. Launch your email client, and create a new message.
  4. Fill in the "To" and "Subject" fields.
  5. Click in the box meant for the body of your message.
  6. Press CtrlV to paste the clipboard contents.
  7. Attach files to your message if needed, and click the Send button.
