TipAtlantis can automatically safeguard copies of all open documents to a temporary folder. In the event of a fatal crash or accidental shutdown of your computer, Atlantis will be able to restore your documents from these "safe copies". Click for details...
Format Brush
The Format Brush tool can be used to transfer formatting between document fragments, or apply various formatting templates to document fragments. When the Format Brush is on, you can use a special mouse cursor The 'Format Brush' mouse pointer to literally "paint" your draft documents. You can add formatting to your documents just as an artist adds touches of color to his/her picture.
You can activate the Format Brush tool by clicking the Format Brush Button image button of the Font toolbar The 'Font' toolbar . The font formatting of the currently selected text would be automatically loaded onto the Format Brush. If you select entire paragraphs before activating the Format Brush, the paragraph formatting of the selection would be also loaded onto the Format Brush. If you entirely select one or more table cells, the corresponding table formatting would be also loaded onto the Format Brush.
After activating the Format Brush, you can start selecting document fragments. Atlantis would automatically apply all the appropriate formatting borne by the Format Brush to each text fragment you select.
To deactivate the Format Brush, just click the Format Brush Button image button of the Font toolbar The 'Font' toolbar one more time, or simply press the Esc key.
When the Format Brush is on, the red-framed buttons of the Font and Paragraph toolbars indicate the formatting currently borne by the Format Brush:
Red-framed buttons
You can click these red-framed buttons to change the current formatting of the Format Brush.
The drop-down menu attached to the Format Brush Button image button displays the Format Palette:
Format Palette
When the Format Brush is off, and there is text selected in the document, clicking these items of the Format Palette applies the corresponding formatting to the document selection. Otherwise the Format Brush is activated, and the formatting of the clicked Format Palette item gets loaded onto the Format Brush.
When the Format Brush is on, you can click the "No formatting" item of the Format Palette to remove any formatting from the Format Brush, then manually add formatting to the Format Brush by clicking the red-framed buttons of the toolbars.
When the Format Brush mode is on,
  • entire words can easily be formatted simply by double-clicking them,
  • entire paragraphs by triple clicking any word inside the relevant paragraph,
  • if the Format without selection option is checked on the "Edit" tab of the "Tools | Options..." dialog of Atlantis, you will not even have to make a selection of text. A single click on the relevant word will be enough to format it when the Format Brush is on.
When the Format Brush mode is on, you can still type text in your document. But it gets automatically formatted with the characteristics currently loaded to the Format Brush.
