TipYou can select a paragraph by double-clicking its left margin or triple-clicking any word of that paragraph.
Installing and uninstalling Atlantis
Installing
To install Atlantis on your device, download its setup file, run it, and follow the onscreen instructions.
Atlantis can be installed as non-portable or portable.
Uninstalling
To uninstall a non-portable copy of Atlantis, use the corresponding command in Windows. Depending on your Windows version, search for "Add or remove programs", "Programs and Features", or "Apps & features" in the Windows "Start" menu or Control Panel. Note that Atlantis Uninstall will not remove the document files you may have created with Atlantis.
To uninstall the portable copy of Atlantis, just remove its home folder with the file manager.
