TipYou can access the current document bookmarks if you right-click the leftmost section of the Atlantis status bar. Click for details...
System requirements
Atlantis Word Processor requires one of the following operating systems:
Windows 11, Windows 10, Windows 8, Windows 7, Windows Vista, Windows XP, Windows 2000, both 32-bit and 64-bit.
Atlantis can also be run on Linux and MacOS via WineHQ or a similar compatibility layer.
The recommended screen resolution is 1024 x 768 or higher.
Atlantis is an offline word processor that can be used without an Internet connection. However, an Internet connection may be required to download certain optional components of Atlantis, update Atlantis, and access the online Help articles.
