TipYou can change the line spacing of a selection of paragraphs by pressing the following keys:
  Ctrl+1 - single spacing,
  Ctrl+5 - 1.5 lines,
  Ctrl+2 - double spacing.
Typing text
Text adding modes
In Atlantis, there are two text adding modes:
  • Insert mode. In this mode, Atlantis inserts all characters you type at the cursor position. With each new insertion, Atlantis pushes over characters to the right of the cursor to make room for the new character.
  • Overwrite mode. When this mode is on, typing new characters replaces any existing characters to the right of the cursor.
To switch back and forth between Insert and Overwrite modes, press the Ins key.
Information about the current text adding mode is reported through the corresponding section of the status bar.
Overtyping selection
When there is selected text in the document, typing automatically replaces the selection.
Atlantis also supports a multiple overtype mode allowing to overtype multiple selected fragments simultaneously. If you make a multiple selection, as shown in the illustration below:
Multiple selection
and start typing, the new text (in our case "Mars") would replace each of the items of the multiple selection:
Overtyping multiple selection
The multiple overtype mode is especially useful for populating table cells. If you select multiple table cells, like shown below:
Multiple selected cells
and start typing, the new text (in our case, "100%") would be automatically inserted into each of the selected cells:
Populating multiple cells
To terminate multiple overtype mode, click anywhere in the document or press Esc.
