TipYou can edit the list of predefined font sizes offered on the Atlantis toolbars. Click the "Font Sizes..." button on the Edit tab of the "Tools | Options..." dialog.
Undoing and Redoing Operations
In Atlantis you can undo any operation performed on your document: typing, deleting text, formatting etc.
So if you have accidentally made an undesirable change to your document, you can easily undo this change.
To undo the most recent operation, click the Undo Button image toolbar button, or choose the Edit | Undo menu command, or press CtrlZ or AltBackspace. You can undo as many operations as you need.
To undo all the operations performed on the active document, click the Undo all Button image toolbar button.
Every undone operation can be redone. To redo the last undone operation, click the Redo Button image toolbar button, or choose the Edit | Redo menu command, or press CtrlY or CtrlShiftZ or AltShiftBackspace.
You can redo as many recently undone operations as you need.
You can also quickly redo all the undone operations. For this click the Redo all Button image toolbar button.
