Robert - this is one of your PhD researchers who adores Atlantis.
My supervisor uses MSWord. She posts back my document with comments in little bubbles down the side.
To see them I use MSWord Viewer.
This has always worked until now but this time it's not good. I found she had marked all down the side that I should give references. Well I HAD - footnotes - but none of my footnotes display in MSWord.
I haven't upgraded Atlantis for a while it's 1.6.5
Also I am now on Win10 (ugh).
When I was using the same level of Atlantis on my old laptop on Win8 my footnotes displayed OK in MSWord.
MSWord compatibility
First, you should show a little love, Shan, and upgrade to version 3 of Atlantis. It has improved a lot since version 1.6.5. As a registered user of version 1.x, the upgrade will only cost you $15. You’ll find all details at Upgrading to version 3.x.
Now all versions of Atlantis work fine in Windows 10.
If your footnotes display correctly in Atlantis, they should also display correctly in MS Word.
