TipThe active document can be saved as a document template. It will then be available as any other template to create new documents. Choose the "File | Save Special | Save As Template..." menu command. Click for details...
The "Text Layout" settings
The 'Text Layout' settings
Justify spaces on line with manual line break (Shift+Enter)
When this option is on, paragraph justification is applied to all paragraph lines including those terminated with a manual line break:
Correspondingly, when this option is off, no justification occurs in paragraph lines terminated with a manual line break:
Do not justify spaces on line with manual line break
Justify nonbreaking spaces (Ctrl+Shift+Space)
When this option is on, paragraph justification applies to nonbreaking space characters:
When this option is off, nonbreaking spaces do not get justified:
Do not justify nonbreaking spaces
Regardless of the state of this option, Atlantis never justifies nonbreaking spaces followed by one of the following punctuation signs:
Click the Save to File... button to save all the current Atlantis settings to an external INI file. To load the saved settings from such an INI file, click the Load from File... button.
