TipYou can create a list of favorite symbols in the "Insert Symbol" dialog for direct access from this same dialog. Click for details...
AtlanTips
Accessing the list of bookmarks in a document
The Atlantis Control Board includes a dedicated Bookmarks panel that you can use to create, view, or delete document bookmarks. But you can also access the list of the document bookmarks by right-clicking the leftmost section of the Atlantis status bar. This will display the bookmarks list:
The popup bookmark list
Clicking a bookmark name in the above menu takes you to the corresponding location in the document. Note that when there are many bookmarks in a document, the target bookmark might not be immediately visible in this list. In this case, it is preferable to type the first letters of the target bookmark. The list will automatically be scrolled and the corresponding bookmark highlighted.
