Atlantis can create automatic and regular backups of all open documents. Successive versions of each document are saved to a special folder. In this way, you can always go back to earlier versions of any document if necessary. Click for details...
Applying styles with the Format Brush
The Format Brush of Atlantis is a convenient mouse tool to apply font and paragraph formatting to an existing text. But the Format Brush can also be used to apply styles to paragraphs. Here is how to proceed:
Activate the Format Brush by clicking the corresponding toolbar button:
Choose "No formatting" from the drop-down list attached to the "Format Brush" toolbar button:
Pull down the "Style" toolbar combo box, and select any appropriate style:
Click in the target paragraphs one by one or select them in the document in any other way to apply the selected style.
