TipIn Atlantis, individual font sizes can have their own custom hot keys (use the "Tools | Customize | Hot Keys..." dialog). The font sizes can then be applied to any document selection directly from the keyboard.
AtlanTips
Closing all documents except the current one
At times, you might end up with many documents open in Atlantis, and realize that only one of them is actually needed. You probably will want to close all open documents except the current one. This is easily done as follows:
First, activate the document which you want to remain open in Atlantis. You can click its button on the Atlantis Document Bar, or click its name in the "Window" menu list.
Then hold the Ctrl key down and click the "Close all documents" toolbar button:
The 'Close all documents' toolbar button
Alternatively, you can hold the Ctrl key down and use the "File | Close All" menu command directly.
