TipYou can print a selection from the active document. Press Ctrl+P to bring up the "Print" window, and check the "Selection" box.
AtlanTips
Drop caps and quotation marks
When you create a drop cap in a paragraph through the "Drop Cap..." command of the "Insert" menu, or the corresponding button Button image of the Insert toolbar The 'Insert' toolbar , Atlantis always drops the first character of the paragraph:
First character dropped
But when the paragraph begins with a quotation:
Paragraph beginning with a quotation
and you create a drop cap, the opening quote mark gets automatically dropped:
Dropped quotation mark
Obviously, this does not look good.
And here is a solution:
1. Delete the opening quote mark – just select it, and press Del:
Deleted quotation mark
2. Use the the "Drop Cap..." command of the "Insert" menu, or the corresponding button Button image of the Insert toolbar The 'Insert' toolbar to create a drop cap:
A dropped capital
3. Click right before the created drop cap:
Text cursor before the drop cap
4. Type the quote mark:
Typed quotation mark
5. Select the opening quote mark:
Selected quotation mark
6. Choose the "Font..." command of the "Format" menu, or the corresponding button Button image of the Font toolbar The 'Font' toolbar . Then apply the desired smaller font size:
Changing font size
and additional vertical offset:
Offsetting text vertically
Then OK out of the "Font Format" dialog:
Dropping a quotation mark plus a capital
