TipYou can reorder the structure of the active document using Drag & Drop in the Headings panel of the Control Board. Dragging the panel items up or down automatically moves the corresponding headings and their associated text up or down the document itself. Dragging in a horizontal direction promotes or demotes the corresponding heading(s) in the active document.
AtlanTips
Scrolling the preview box in the "Open Document" dialog
The "Open Document" dialog offers previews of the documents that you highlight on the left:
Document preview types
When the preview is long (as in the above screen capture), you might need to scroll it up or down. You can use the scrollbar located to the right of the preview. But you can also use the cursor keys. Clicking the preview, then pressing the cursor keys (Left, Right, Up, Down, Home, End, PgUp, and PgDn) will scroll the preview in the corresponding direction.
