TipYou can reorder the Document Bar buttons with Drag & Drop.
AtlanTips
Text translation side by side using a table
Here is how document text can be translated using a table with the source and translated paragraphs displaying side by side:
1. Open the document that should be translated:
Open document
2. If the document's page orientation is Portrait, click the "Change page orientation" button of the File toolbar The 'File' toolbar :
The 'Change page orientation' toolbar button
Landscape orientation
3. Press CtrlA, or click the "Select all" button of the Edit toolbar The 'Edit' toolbar :
The 'Select all' toolbar button
4. Click the "Insert table" button of the Insert toolbar The 'Insert' toolbar :
The 'Insert table' toolbar button
and convert the selection into a table:
Convert text to table
Text converted to table
5. Add a new column to the table:
Adding new tabl column
New table column
6. Click the "Default Language..." command from the menu attached to the "Language" button of the Tools toolbar The 'Tools' toolbar :
The 'Default language' menu command
and choose the language into which the source text should be translated:
The 'Default language' dialog
7. Start adding translated text to the second column:
Adding translated text
8. After completing translation, select the first column – hover the mouse pointer over its top edge, and click:
Selecting table column
9. Press the Backspace key, or click the "Delete cells" button of the "Table" toolbar to delete the first column:
The 'Delete cells' toolbar button
Table column deleted
10. Click the "Convert table to text" button of the "Table" toolbar to remove table formatting:
The 'Convert table to text' toolbar button
The 'Convert table to text' dialog
Table formatting removed
