TipYou can change the line spacing of a selection of paragraphs by pressing the following keys:
  Ctrl+1 - single spacing,
  Ctrl+5 - 1.5 lines,
  Ctrl+2 - double spacing.
AtlanTips
Using floating pictures to create page backgrounds
You can create more visually appealing documents by adding a background image to the document pages. It can be a roll of old parchment, a decorative page frame, or a logo watermark:
Page backgrounds
On the Web, you can find many different background images, both free and paid. You can also design your own image.
Here is how to add a background image to a document in Atlantis:
  1. Choose the "Header & Footer..." command of the "View" menu, or click the corresponding button Button image of the View toolbar The 'View' toolbar .
  2. If the background image is available on the Windows clipboard, just press CtrlV to paste. If the background image is stored on a disk as a graphic file, use the "Picture..." command of the "Insert" menu, or the corresponding button Button image of the Insert toolbar The 'Insert' toolbar to insert your graphic file.
  3. Click the inserted image to select it:
    Selecting picture
  4. Click the "Picture layout" Button image button of the "Picture" context toolbar, and choose "Behind text" as a text wrapping style:
    'Behind text' wrapping style
  5. Resize and reposition the image with the mouse in the desired way:
    Page background
  6. Click the "Close header/footer" Button image button of the "Header & Footer" context toolbar to switch to the document main text.
  7. You are now ready to start adding actual text to your document:
    Page background
Note that when the document main text is active, the headers and footers are dimmed. This is an onscreen display only, and the headers/footers will print in full color. For the WYSIWYG preview, use the "Print Preview" command of the "File" menu, or click the corresponding button Button image of the File toolbar The 'File' toolbar .
You can download the sample document file used in this article by clicking here.
