TipFor information about word count, line count, sentence count, etc., of a selection or of a whole document, choose "Tools | Word Count..." or double-click the "Word Count" section of the status bar.
Creating documents
You can create a new document by clicking the New document Button image toolbar button, or by choosing the File | New | Document menu command, or by pressing CtrlN.
You can use various document templates for creating your own documents.
By modifying document templates, you can control how Atlantis will create new documents.
You can quickly create a new document from the desired document template. For this, choose the File | New | Create From Template... menu command, and choose the desired template.
On the Atlantis site you can find a collection of sample documents that you can use for creating your own documents. Click here to browse this collection.
Tips:
  • You can quickly create a new document and place it on your Windows Desktop.
    For this, right-click a blank space of the Windows Desktop, and choose the New | Atlantis Document menu command.
  • The drop-down menu of the New document Button image toolbar button allows to quickly create a new document of the required format:
    New document
