TipYou can choose document templates to be used for creating new documents by clicking the "File | New | Formats & Templates..." menu command. Click for details...
Closing documents
To close the active document, you can:
  • click the cross button in the right corner of the title bar of the document window:
    Closing document
  • choose the File | Close menu command.
  • press CtrlW.
  • grab the document's button on the Document Bar and drag & drop it outside the Document Bar.
To close all open documents at once, click the Close all documents Button image button of the File toolbar The 'File' toolbar , or choose the "File | Close All" menu command. Note: you will keep the active document open on its own if you press and hold the Ctrl key when using the "close all documents" command.
To reopen a recently closed document, use the drop-down menu of the Open document Button image button of the File toolbar The 'File' toolbar :
The 'Recently closed' menu
or choose the "File | Recent Documents | Recently Closed" menu command.
