TipYou can select a line of text if you aim at it from the left margin with the mouse pointer, and click.
Drag & Drop
With Drag & Drop you can move fragments of text between different locations of a document, between documents in Atlantis, and even between Atlantis and other word processing applications. Just select a text fragment that you want to move, grab it with the mouse, and drag to the required location.
If you want to duplicate the selected text (to insert its copy to another location), hold the Ctrl key pressed while dragging.
Note. Moving or duplicating text in Atlantis with Drag & Drop is possible when the Drag & Drop option is checked in the Tools | Options... > Edit dialog.
You can also use Drag & Drop to open documents in Atlantis and insert files to the active document.
So if you want to open a document in Atlantis with Drag & Drop, grab a document file (or multiple selected files) with the mouse in your file manager (normally in Windows Explorer), drag them to the Atlanis main window, and drop onto the Atlantis status bar, document bar, toolbars, or main menu.
If you want to insert documents or graphic files to a document in Atlantis, grab a document file or a graphic file or multiple selected files with the mouse in your file manager, drag them to Atlanis, and drop to the desired location in a document.
Tip:
  • When you drag anything over the document bar of Atlantis, you can place the mouse pointer over a document button without releasing the mouse button for about a second. This will activate the corresponding document window and you can then drag the item into the document window.
